- Sep 29, 2019
- 3,060
- 7,071
- Hymer Exsis
- 20 years
In a similar theme to my other threads, I will be posting this as I go along.
In the Hymer Exsis the whole electrical system is protected by an RCD which feeds a 10amp MCB. That’s it, everything in there is on the same circuit. No big deal but if the supply gives 16 amps, you can’t use more than 10 without the MCB tripping which is annoying.
It has also been annoying me only having one mains socket at the inverter but other than unplugging the battery charger and manually changing the fridge over, the one circuit meant I couldn’t connect it direct. To rectify this, I have decided to change the consumer unit and wire in a changeover switch.
After reading lots of threads, I managed to find a DIN rail mounted changeover for the inverter and hook up that goes inside the consumer unit. As I need to change the consumer unit regardless, it seemed a neat solution and to change over, I just flick the switch and turn off the fridge and charger circuits as the same time.
I need to run new cables for the charger and fridge and swap the consumer unit out. Then run a cable to the inverter, a job for tomorrow now but everything is ready.
