Mine is mainly for reversing but I have used it for rear view when checking things behind us. I've wired it to the rear lights so it doesn't need the reverse light to power it.Do you use your current camera as a ‘rear-view mirror’ too, Mattyjwr , or do you have a rear-view mirror? The BC40 wouldn’t really be suitable to be permanently on as it is battery-powered…..
Mine is a PVC. Wired would work but wireless would be easier.For a Ducato type van, it's not that hard to get wiring to the front. If you can get the trim off, there's an open channel across the top of the rear doors and down the sides (past the lights where you might want a reversing light signal) that's easy to run wiring through. It drops out of the bottom of the van. Running wires in a bit of flexible conduit that's p-clipped or cable tied to the chassis is simple. And there's a grommet in the base of the b-pillar behind the driver that gets you into a nice cavity inside the van. There's a cable run that goes from there to the dashboard.
