Hi all, I have just connected a test lead to my allocated electric bollard and got a reverse polarity warning on my plug in circuit tester, how is that overcome or can it not be?
Mike.
Mike.
excellent, thanks for the confirmation Lenny
Not quite true. It does not matter where a fuse is in the circuit. Yes part of the appliance will remain live, but the protection offered by the fuse, limited though it is these days, will still be there and the appliance will stop working.My understanding is that the on-off switch and the fuse of an appliance are on the live wire; therefore, if the polarity is reversed, the appliance remains live, bypassing the fuse and switch - it will still work but you loose the protection offered by the switch and fuse should short circuit for example. That said, an RCD should save the day if it all goes wrong.
If the neutral is live ("reverse polarity") and the fault is to earth then the flow of current will bypass the fuse.Not quite true. It does not matter where a fuse is in the circuit. Yes part of the appliance will remain live, but the protection offered by the fuse, limited though it is these days, will still be there and the appliance will stop working.
The fuse is to protect the appliance and if you are worried about reversed polarity fit sockets wit double pole switches.Not quite true. It does not matter where a fuse is in the circuit. Yes part of the appliance will remain live, but the protection offered by the fuse, limited though it is these days, will still be there and the appliance will stop working.
As pappajohn says, everything works the same. There is a possible safety problem in the event of a fault. If your motorhome mains inlet box has an RCD, that will give you protection against possible safety problems due to reverse polarity or anything else.Hi all, I have just connected a test lead to my allocated electric bollard and got a reverse polarity warning on my plug in circuit tester, how is that overcome or can it not be?
If the neutral is live ("reverse polarity") and the fault is to earth then the flow of current will bypass the fuse, but then cause the RCD to trip, so no problem.If the neutral is live ("reverse polarity") and the fault is to earth then the flow of current will bypass the fuse.
It can also bypass the single pole RCD fitted to some British vans which is why this fault can be potentially dangerous in some vehicles.
You beat me to it! But mine was an image of a lady standing up……..Wasn't there a thread about a chap who thought his toilet had reversed polarity as he could pee only when sitting down?
Yes, easy. Single pole:Can one tell visually if an RCD is single or double pole?
Let's be clear about this. The 'Single Pole RCD' is a type of RCBO, in fact a double pole RCD, combined with a 'Single Pole and Neutral' (SP&N) MCB. Because that's a bit long-winded, it gets abbreviated misleadingly to Single Pole RCD.Yes, easy. Single pole:
Double pole:
Or fit ones without a switch. None of the UK sockets in my motorhome have a switch which makes it clear that to be safe you need to unplug appliances. I am surprised that single pole switching is ever allowed, it assumes that no one ever makes a mistake with wiring.The fuse is to protect the appliance and if you are worried about reversed polarity fit sockets wit double pole switches.
Looks fine to me. On the left is an RCD: double pole, trip current is 0.03A, ie 30mA, which is low enough to avoid serious electric shock. It's a Type A, which is fine for this usage. It's amp capacity is 40A (not visible on the photo) which means it can be used in installations up to 40A total current.This is my box, can you tell what this is? How safe is this?
Thank you for the correction, thinking about it, that makes sense.Not quite true. It does not matter where a fuse is in the circuit. Yes part of the appliance will remain live, but the protection offered by the fuse, limited though it is these days, will still be there and the appliance will stop working.
Not true. Yes an RCD may monitor the current in both wires but a single pole one (SP) only disconnects one connection and if the polarity is reversed it disconnects the wrong one. A double pole one will disconnect both connections.There is NO SUCH THING as a Single Pole RCD!
An RCD monitors the current in both phase (live) and neutral, and if it detects any imbalance of 30mA or more, disconnects the supply in no more than 40 milliseconds. That is vastly quicker than any type of fuse/mcb & is what saves lives.
It will NOT detect reversed polarity - which may or may not cause damage to your electrical system, but can easily be corrected by making yourself a simple "reverser" using male & female blue 16A fittings, with the linking cable crossed over at one end.
I have carried one of these for years & used it many times, especially in Italy, where the natives have a somewhat casual attitude to electrics.
Cb.
This is a Single Pole RCBO. It is a single-pole RCD combined with a single-pole MCB. This can be fitted in UK domestic circuits, and it is vital that the live and neutral are not interchanged. They should not be fitted to mobile units like motorhomes and caravans, where there is the distinct possibility that incoming live and neutral can be interchanged (ie 'reverse polarity').There is NO SUCH THING as a Single Pole RCD!
