Scout
- Apr 4, 2009
- 4,009
- 142,694
- chic c line
- 12 years motorhoming, a lifetime of living
I have a broken polyplastic window, it looks like somebody at some piont has tried to gain access by jemmying the window, and has caused a small crack which is now starting to cause problem. I have sourced an new window and frame and I will be collecting it at the weekend, my diy skills are average is this job do able diy or should I let a "man that can" do it. I understand its a two man job, but I not 100% sure whats intailed,
A:take off inner frame, blind/flyscreen
B:get somebody to hold the window from outside
C: loosen (diagonally) the screws hold frame clips
D:remove screw and frame clips
E: ease out window from outside (using blunt blade if needed)
F: clean up frame opening
G: refit in reverse order double checking screws are tight but no overtight
is that it or have I missed something
