I also need some rather urgent help. I need to get a replacement POLYPLASTIC window.
Finding it difficult to get anyone to get back to me with solid info.
Can anyone here help with quick & reliable window replacement?
I was going to suggest that you check the window (thinking that it was damaged) for a part number etched into a corner. But it looks like the opener is missing.
Anything on the frame?
Any caravan breakers nearby?
oouuuu.... Caravan breakers. That sounds like it has possibilities. Thanks
Just search on internet for breakers?
My main problem is that all of the ‘parts companies’ won’t pick up the phone - they just want you to send the information via email and then they don’t get back to you. Ughhh...
Have you rung Autotrail? You might need to provide them with the vehicle VIN (chassis) number. If they don’t have stock any longer perhaps they can give you the name of the manufacturer and the model name/number?
This bloke has a container full of second hand ones. Just need measurements. https://www.essexcaravanbreakers.co.uk/
I got a replacement for my over cab from him on the last van+ another 2 last summer for this van
if there is a delay, and you need to keep the weather out. A piece of plywood that is bigger than the opening and a length of wooden batten on the inside and connect them with 2 long bolts with nuts
