Oldgustaf
We have an 11 year old, 7m Dethleffs low profile coach built rated at 3,500 kg. We've had it for just over two years. It hasn't had much use from so far (and we never overload it). I'd notice that it was a bit down on the nearside rear and on closer inspection, the leaf spring is almost touching the bump stop. The offside has about 25mm clearance. I've not been unhappy with the handling of the vehicle and don't really want the outlay of several hundred pounds for semi-air suspension (despite all the good things I've read about it). So quite happy to just replace the leaf springs with a new set. The only thing is... should I go for a double leaf and if I do, will this make the ride even firmer than it already is? I have found two UK manufacturers who make double leafs but haven't found anyone selling single leaf. Would the suspension have been uprated by Dethleffs for use as a motorhome? We have a short (1,000 miles max) UK trip planned for two weeks time and I can't get it fixed in the the time available. Do you think it's okay to drive it in it's present state? Will I do any damage the the chassis if the nearside is leaf is constantly hitting the bump stop? Photos show off side leaf spring and bump stop with little clearance, nearside leaf spring and bump stop with over an inch of clearance, offside view sitting nicely, nearside view with rear sagging. Many thanks for your help.
