Renault Master horn (1 Viewer)
Kanberlingo
91
Lancashire
Low Profile
10yrs. & 20yrs towing.
Hi, Is anyone out there that can indicate where the horn is situated on a late 2007 Master. My Chausson Allegro83 is on this base vehicle & I want to fit the air horns that I took off my previous MH. The horn on the Chausson sounds like a cat, that's had its dingly dangly's squeezed. :Eeek:
I'll be taking the feed from the horn as the feed for the relay switch, when I can find it.
I know it's in the engine compartment :ROFLMAO:but where?
Cheers
BeeJay
gazznsam
273
Eastwood, Notts
where ever it is, it'll be in such a place that you make the noise of a cat with it's dingely-dangelies being squeezed as you try and get to it :roflmto:
usually they are behind the bumper tho, get someone to press the hooter button and have a listen.
thewilse
Hymer
2 years
on our master it's on the the left hand side stalk... at the end... with the 'horn' logo:roflmto:
Kanberlingo
Kanberlingo
91
Lancashire
Low Profile
There's always one. Must be the weather:winky:
I've obviously tried that gazznsam, but no joy. On my last MH, the AutoSleeper Executive, I had to dismantle the front grill & remove the N/S headlight just to get at the wiring for it.
If I can't sort it, which I will,:Cool: I'll open a window at the appropriate time of an impending "coming together" & get SWMBO to shout. That'll shift 'em.
@ thewilse, & before you ask why she'd shout "That'll shift 'em" ..............:Blush:
Cheers
BeeJay
S
stagman
Cheers
BeeJay
I know this is a bit late but seeing as you not had an answer .The Horn is under the Pass side front wing not under the bonnet:thumb:
Kanberlingo
Kanberlingo
91
Lancashire
Low Profile
Hiya stagman,
Thanks for the belated info. Good on yer! I should really have posted up, that I'd sorted the horn jobbie. I decided to get off my backside & take a proper look see after my last post. :Blush: If I'd done that in the first place...........
It's in such an easy position that I've fixed the air horns, compressor & relay to a bracket, so they can be removed in one lump, in minutes, for when I swap this MH for the next one.
Cheers
BeeJay
