Removing strip ceiling light cover
Is this a frosted cover with a switch at one end? If so you pinch it in carefully, four little feet 2 each side take it slowly and tube is revealed.
Any pictures?
if you are stripping it down to convert to LEDs, be careful as you remove the guts, as it is a mini inverter and can give a good shock at 220v
Not the one I was thinking of, however I think it is attached much the same. Maybe the lugs are on the softer plastic base? Use a good torch to identify the fixing points. Horizontal photo shows a darker patch midway along the side perhaps just one point each side, gentle pressure under the diffuser on the base may release it?
Thank you for the advice(y)
