Does anyone have any suggestions for an internal camera to feed to phone or iPad. I am going to have park my van a short distance from my home out of sight of current security lighting and cameras so I need to have cameras inside.
Does the camera constantly use data, or just when it detects motion or is logged into by the user to monitor ?the expensive bit is having a Vodafone data card running in the motorhome
But not connected to power?The van has boosted WiFi fitted with SIM card so don’t need a system that has one built in
Yes that’s right, 190amph leisure battery and 160amp solar panel, and as I use it every day so it gets a little charge from the alternatorBut not connected to power?
I use a couple of EZVIZ cameras but they need permanent 240v.Yes that’s right, 190amph leisure battery and 160amp solar panel, and as I use it every day so it gets a little charge from the alternator
Unlikely to get that power source.I use a couple of EZVIZ cameras but they need permanent 240v.
Another vote for Neos Smartcam.For future searches I used NeOS SmartCam - Amazon UK link
Dirt cheap and sends alerts on motion/noise delta and only uploads screenshot every so often so sips data. USB powered. 1080p but image a bit soft(excellent for the price). In the process of fitting one to mine at the moment.
No, I do t believe so but I may be wrong. It seems to only consume data when activated by movement etcDoes the camera constantly use data, or just when it detects motion or is logged into by the user to monitor ?
If you have an old smartphone there are many apps that will turn it into a remote security device.
May I ask how you do that ?Search Aiwit. You can use any old smart phone as a camera and see live action on your phone.
I used an app called Presence Video Security(?) .......... If I remember correctly you install it on 2 devices and both need internet. I don't use it now the need has finished.May I ask how you do that ?
I downloaded the aiwit app mentioned above, and it only seemed to want to connect to a door bell camera.
I use an app called XMeye for cctv cameras and tried to use that to connect to phone camera but could find no method of identifying the phone / camera I want to connect to ? Is there a unique serial number on the phone I wonder ?
Any help gratefully received
Ctronics rechargeable battery camera with push notifications of movement.The van has boosted WiFi fitted with SIM card so don’t need a system that has one built in
I have. ring stick up cam in the Motorhome, the house Wi-fi reaches the van easily, if your van is parked a little way from the router get something like a power line adapter to extend the WiFi closer to where you need the Wi-fi signal. I have a ring alarm (door sensors and keypad which sounds and alarm) and cameras in my garage which is at the bottom of my garden. I have power out to the garage so the power line adapter just sends the data signals over the 240v network.Does anyone have any suggestions for an internal camera to feed to phone or iPad. I am going to have park my van a short distance from my home out of sight of current security lighting and cameras so I need to have cameras inside.
Yep, I have two at home and they both work perfectly. I've had them a couple of years but don't remember the set up being at all onerous either. I also have the subscription which allows longer video clip storage and less time between clips. About a £1.00 a month I believe.I have the NEOS camera in my van, it works well. I didn’t find the sign up procedure particularly onerous, they don’t have my address, when asked for location I just put “campervan”.
Ring indoor cam. Runs from mains (via adapter) or USB (including a power bank for a few days). I run mine through a MiFi dongle. Works a treat. Also integrates in to my Ring dashboard so I see it along with all my other Ring cameras. Amazon product ASIN B07Q769MFM. Image and sound quality are excellent.Does anyone have any suggestions for an internal camera to feed to phone or iPad. I am going to have park my van a short distance from my home out of sight of current security lighting and cameras so I need to have cameras inside.
