Remis are stiff up and down (1 Viewer)
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
Notice that our Remis on the side windows have gotten quite stiff over the last couple of months. These are the ones on the kitchen, side windows and not the classic windscreen or drivers/passenger door types.
The version is called REMIbase II:
Any ideas of how to make them a little easier to slide up and down ? Had a quick look at the mechanism to see if it was something that may need some Teflon spray but doesn’t look like it would help and also conscious that it may stain the paper blind itself.
Aug 13, 2022
288
713
Chesterfield, UK
Autosleeper Sussex
On ours I noticed that some of the pleats at the edges were a bit crumpled, although it didn't affect their performance, it may be that causing them to bind on the cord and just needs straightening?
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
On ours I noticed that sow of the pleats at the edges were a bit crumpled, although it didn't affect their performance, it may be that causing them to bind on the cord and just needs straightening?
Will take a look at that. Thanks
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
If you remove the two top corner covers you will see a grub screw you can tighten or loosen to make the blind go up and down a bit easier , just adjusted one of mine
You’re a star !!!
We give that a try this week.
:thanks3:
May 16, 2023
98
78
CV40
You can see it in this pic, little black circle is the grub screw, it has the strings running through to tighten or loosen.
Feb 27, 2011
14,741
76,048
UK
Self Build
Well that title made me double take. :whistle2: :Eeek::ROFLMAO:
