And how many £1000s?Improves the ride height and handling, without them front end tends to bottom out on large bumps. Even better don't bother and get full air fitted.
Sorry to say you may well "need the extra". Depending on which model you go for (Tourer, C-Line, E-Line etc) they all get heavier as you go up the range. Ours was a 4250 but came very close to blowing the rear axle limit with the motor bike in the back, I could have left it but wanted some headroom for full water, beer, wine,.. you get the idea ;-) So we went with semi air, new tyres and 4800 kg max, 2700KG rear axle so up 200kg. A mate with a C-Line had to get re plated with a scooter in the back, E-Lines are heavier again... We max out at about 4300kg with full water and about 2550kg on the rear when loaded for a long trip. FYI the factory upgrade to 4500kg doesn't increase the rear axle load, only rear air and tyres can do that... I think.Going for the 4250 option so don’t think I need the extra. But nice to know just in case!
Full air around 6½ and worth every penny, we had to have Goldsmittch on ours a bit dearer. I would never have a van without it now.And how many £1000s?
You should be fine then. But be aware Carthago are fibbers about the actual weight like all of the van manufacturers, ours with all the extras should (on the paper figures Carthago quote) have been X kg. From memory or was about 40-50kg over. Not an insignificant amount to loose, and that was without the gas bottle, water and driver so in reality more like 150kg over the MIRO paper claim. They do have good payloads so it isn't down to the last kg normally.We currently run at about 3550 with full everything on a 3850 chassis. The I150 QB has a MIRO about 100kg more than our Burstner so we have some in hand. We can’t bring back loads of wine anymore which we had accounted for in our load calculations so a bit more saving. Oh, and we don’t carry a motorbike!
What you having fitted Goldschmidt or an alternative.Ask me on Saturday, having upgraded front springs fitted to our Peasant Tourer on Friday. Did Scotland in June and the front suspension was struggling with the potholes (Semi air on the back). Bad enough for me to get my wallet out..
Can't remember the make tbh, some of the quotes were eye watering. A mate had it done on his C-Line and it has transformed the front end ride, as soon as I went in his I booked mine in. Not Air suspension quality but good enough for us and we already have the E&P levellers.What you having fitted Goldschmidt or an alternative.
I agree but the bank account is only so deep and full air is the cost of a good motorbike Maybe go in the budget for the next van if I win some PB money...Personally, full air is the way to go. Its like day and night comparing with and without.
Everyone I know who has had a new Carthago the MIRO has been over by 125 - 130kg, the smallest of the Compact Line is about the only Carthago A Class that is runnable at 3500kg.You should be fine then. But be aware Carthago are fibbers about the actual weight like all of the van manufacturers, ours with all the extras should (on the paper figures Carthago quote) have been X kg. From memory or was about 40-50kg over. Not an insignificant amount to loose, and that was without the gas bottle, water and driver so in reality more like 150kg over the MIRO paper claim. They do have good payloads so it isn't down to the last kg normally.
We found with semi air and all weather tyres the ride was perfectCan't remember the make tbh, some of the quotes were eye watering. A mate had it done on his C-Line and it has transformed the front end ride, as soon as I went in his I booked mine in. Not Air suspension quality but good enough for us and we already have the E&P levellers.
Yes I have noted your comment in the past. When I spoke to Southdowns they said that no-one orders the Fiat light chassis.Everyone I know who has had a new Carthago the MIRO has been over by 125 - 130kg, the smallest of the Compact Line is about the only Carthago A Class that is runnable at 3500kg.
