- Jan 28, 2008
- 10,116
- 18,382
- Renalt burstner
- 7 years campers before that
well my reich ebox has bitten the dust and as camper uk are quoting me £2300 plus i might need a temp sensor and new screen to go with it i've decided it has to go.basically it's a battery charger some fuses and a split charge relay in a box.im going to loose some of its functions that work via the electronics inside the box such as tank gauges and outside temp sensor but i can sort them later .
i never used the screen as a on off switch for the lights etc as i've got leds with switches in most places so its a massive wiring all the feeds up via some fuses adding a stand alone charger from ehu and either a split charge relay or b2b
ive got a schematic of whats what on the plugs strangely i cant find a seperate fuse/terminal for the truma as far as i can see at present the power goes out in three groups living kitchen and bed areas and i suspect the truma will just be connected to the bed area seems they don't split lighting and power as i can see the wiring in the kitchen goes to both a hella socket and the lights. unfortunately none of the wiring diagrams show any cable colors
first job seat off and a picture of the spaghetti
im sure i will be back with a lot of queries
wish me luck
wish me luck
