Reich cwc scales
Essex
Low profile
Joined 2014
Has anyone used them as used once on my caravan but now each wheel on display flashes but no weight is recorded
Hi thanks for coming back to me
I’m driving very slowly the display ones up with each wheel flashing for that wheel to be measured but doesn’t record the weight
I tried setting it on caravan tag axle and it does measure jockey wheel only
Wonder if there was a reset button
I bought these some years ago for my caravan which I never used and now thought it would be ideal for the motorhome
The only thing I can think of either faulty or need recallibrating ?
Is the weight too heavy and therefore "overloading" the scale?
I use these scales from time to time. They aren’t totally accurate ( when compared with weighbridge) bit they do help to trim the van and ensure we aren’t drastically over.
In the past the registered weight has become very erratic, cured by battery replacement. I regularly get the “rabbit” symbol caused by moving too quickly, cured by a bit more care and control - I’m just getting used to an auto gearbox.
I haven’t come across your problem but I tend to write down the weights for each wheel as we do it to avoid losing the numbers if we have to reset.
there are 2 models, one for caravans and a heavy duty one for motorhome weights
