Perhaps foolishly (in retrospect!) I washed out the water system with diluted acetic acid. I drained it and then refilled the system. The pressure seemed a bit less after doing this despite getting a good gush of water/bubbles when refilling. Initially the pressure was worse in the end tap of the system but I decided to drain down again and refill and now it affects all the taps (and both hot and cold). Suspect that I have some loosened scale blocking the system. Can I flush it through with mains water or is that pressure likely to damage the system (our domestic mains pressure is not very high). Was thinking if I disconnected the pump and flushed through by attaching a hose to the end tap (on cold then hot with the 12v turned off as it is a microswitch system) it might clear it? Any thoughts most welcome!
