capitanoooo
- Apr 19, 2020
- 1
- 0
- VW T6 SWB 2016
Hi All,
I was wondering if anyone out there may help me with a solar panel problem that I am experiencing? The vehicle is a 2016 T6 converted by Autohaus.
I have an <Broken link removed> which is Silkaflexed to the top rear of Reimo roof (please see photos). The flex from this panel runs to the underside of the roof, along to the front of the vehicle where it then drops into the headliner, it is then extended from here down the drivers B post to under the seat terminating into a STCC10 solar charger.
I have an intermittent problem with the panel that even when the panel is in direct sunlight and is super clean, it mostly sits at about 10 volts. Obviously at this voltage it will not charge the 12v leisure battery and becomes completely pointless. On just a couple of occasions it has measured around 18 volts, which in general light of day is what I would expect from this panel, and the light comes on at the controller charger informing me that it is charging the battery - which on testing it is! But as I say, most of the time it is around 10 volts - when panel is squeaky clean and in direct sunlight!
I have removed the headliner and checked the voltage (open circuit) with a multimeter at the end of the flex leading from the panel. There are no other terminals/connections before it enters the panel's moulded junction box (mechanical and chemically fixed on the panel) and there appears to be no damage to this flex. The voltage here is still at about 10 volts. So I have ruled out a bad connection or any earthing problems prior to the panel and its junction box.
I can't see any damage to the panel cells and I'm under the conclusion that if it has occasionally given me 18 volts that the panel cells should be okay and an intermittent fault would be unlikely from a cell?
I had some other advice that suggested the problem may be within the moulded junction box on the controller which supposedly contain diodes to prevent back feed into the panel's individual cells. It was suggest that if one of these are faulty and blocking a cell then I should expect to see a significant drop in voltage. I was wondering if anyone would agree with this or has experienced any similar problems?
I have contacted the manufacturer Solar Technology International but still awaiting to hear back from their support team. There is a 5 year warranty with the panel so thinking it should be covered but who knows with these things! I'm reluctant to pull the moulded junction box apart as if I am covered by warranty, then don't wish to null and void it in the process.
Can anyone think of any other possible causes or items that I should test first. Any advice would be greatly appreciated!
