Pure sine wave for Microwave
Dalbeattie
Van conversion
FUNSTER in a PVC
I have a Bosch microwave/grill in my van which we only use on EHU as it’s 900w model, I have a 3000w invertor (not pure Sine Wave).
Question- Do I need to replace existing invertor to use Microwave off grid ? Or will the existing invertor be up to the job and not damage the microwave?
Electricity in its many creations is not my thing, I still cannot get my head around Amps, Watts, battery life, etc.
Be aware that the 900W that you quote is the heating power and not the power consumption figure that’ll more likely be around 1.3kW.
Ian
I would yes you need PSW, when we bought our last van it had a Quasi sine wave and when I fitted a microwave it went through the motions and did everything but heat anything up, changed to 3kw PSW and "bingo" it worked a treat.
I can not think of any reason why the equipment ratings you describe would do any harm to the inverter, but I would not risk the electronics in the microwave oven with a non-pure sine wave model.
Also, you need to be sure you have adequate battery capacity to run a microwave oven for the time required....... when running it is likely to be drawing a current of at least 80 amps and probably nearer 100 amps, depending on the efficiency of your inverter etc. So, as a guide, if you run your microwave for 15 mins you will use something like 25 Ah (Ampere-hours) of your battery capacity.
You don’t say how much battery capacity you have. Unless you have increased the size of your battery bank, a typical Panel Van Conversion is equipped with a single leisure battery of (usually) no more than 100 Ah, of which you cannot really expect to use more than 50 Ah (unless it is, for example, a Lithium Battery) without seriously reducing the life-span of the battery. Bear in mind also that you will have other power demands drawing current from your battery when off-grid.
Hope this may be helpful.
Battery is 190ah AGM at present, not so much concerned about the invertor being damaged it is the microwave I was concerned would be ok to operate with non PSW.
You really need 3 batteries to supply 100 amps, so they supply a more battery friendly 33 amps each. Or there's the lithium option 🤔
For a quick work out, divide the total battery capacity by 5, and will give your max draw amps. In your case 190ah : 5= 38a draw. Take that via inverter 38a x 12v = 456w. Take 10% for efficiency of inverter, 45,6w, that leaves you with a max 410,4w max at 230v. You really need 3 times as much to run that 900w microwave. Also it’s a very inefficient on power factor. The inverter will supply 1000w, ( apparent power), but microwave it will only absorb 800w. The 200w is a reactive power that returns to inverter and cycle starts again. This would be a 0,8 power factor. Anything we plug in our sockets could be from as low as 0,6 to 1 power factor. A boiler heating element will be 1 PF as it’s a resistive load and will swallow anything you trow at it, even dc, it wouldn’t care.
Cheers this I think I can understand, simply, don’t use Microwave off grid😉😉😉😁😉
