Power tripped out Carthago (3 Viewers)
Apr 7, 2015
20
94
Horley, Surrey
Have blown the plug sockets in the van. Lights and fridge working on EHU but no sockets. All the fuses and breaker units seem to be OK.
But one breaker only works when the inverter is on, as do the plug sockets.
Any idea what the problem could be please?
May 7, 2016
7,264
11,755
West Sussex
Since 2003
Try tuning the breakers off and back on. Sometimes they need to turned completely off to re engage the resetting mechanism.
Reactions: f6c
pauljanita
Apr 7, 2015
20
94
Horley, Surrey
Have tried that, still no luck. Also the control panel inside the van has now turned itself off completely?
May 7, 2016
7,264
11,755
West Sussex
Since 2003
I think CBE panels/DS units have a low voltage shut down. Have you checked your battery voltages?
May 7, 2016
7,264
11,755
West Sussex
Since 2003
How are your mains supply and inverter separated? If the sockets are live with the inverter on but not with mains perhaps worth checking whatever device you have for keeping them separate.
pauljanita
Apr 7, 2015
20
94
Horley, Surrey
Do you know where the inverter is? I’m looking all over the van but locate it.
53,493
150,285
Sounds like your system is set up to swap the power sockets over from the inverter to the mains input when on EHU. The relay is not switching over therefore the sockets are still connected to the inverter. Could be a loose connection, a faulty relay, the relay could be fused separately. Just a case of tracing the wiring and find out what is going on.
  • Informative
Reactions: f6c
53,493
150,285
Where the inverter is - normally if fitted by someone with some brains it will be near the batteries to keep the 12v cable runs short, often in Carthagos in the double near the batteries.
Apr 27, 2016
6,876
8,002
Manchester
A class Hymer
Since the 80s
Start at the beginning. Have you checked you are still getting mains power from the EHU supply socket? The lights and fridge could be working from the battery.
Has the system always worked well , but has suddenly developed a fault? Or are you doing something new and something has gone wrong?
32,673
66,645
By double you mean the large centre floor locker accessed internally?
Apr 27, 2016
6,876
8,002
Manchester
A class Hymer
Since the 80s
I'd agree with Lenny HB that it's related to the changeover relay that switches from mains to inverter automatically. This relay will probably be located either inside the Consumer Unit (the box with all the mains fuses/breakers) or in a separate box just near it. Most electrical problems in devices subject to vibration and damp are loose/bad connections rather than failed components.
denisejoe
5,625
12,055
Warden isle of sheppy
Is your fridge and lights working on 12v or 240v as the light in the fridge is 12v and so are your lights unless you have 240v lights on the breaker there will be a master on off and some for each circuit check all
53,493
150,285
Some inverters like the Waco have the relay built in.
pauljanita
Apr 7, 2015
20
94
Horley, Surrey
Thanks for all your help. We have now managed to find the inverter under the floor and it has a reset button. The plug sockets are now all working correctly.
However, the control panel now works, but only if we remove the SOS fuse from the fuse box, pic below. But as soon as we replace the fuse, which hasn’t blown, the control panel does not work. It seems strange that by removing the fuse, the unit works! Any ideas what this fuse is for?
53,493
150,285
SOS fuse is a by-pass to power systems in an emergency, it's not supposed to be there in normal operation.
Info from CBE website:
Although CBE products are built to the highest quality standards, these components too might be sensitive, e.g. to electric shock or external disturbances. In the rare event of a failure to the control panel or distribution module, a drawback of modern systems is that more often than not almost nothing is working, not even basic users such as the heater, water pump and lights.
On the contrary, thanks to the DS470 built-in SOS function, end customers just need to insert a fuse in the fuse casing, to provide direct power for the heater, water pump and lights. This allows end customers to ensure that their vehicle will complete its journey before being brought in for servicing. In terms of accessories
pauljanita
Apr 7, 2015
20
94
Horley, Surrey
Update....our control panel is now working. After discussions with Carthago in Germany, we realised that the 3amp fuse did not belong in the SOS slot! Now just waiting to get going over to France!
Thanks all for your input, it’s been very much appreciate.
