No idea, people fit them in lots of different places. Was your inverter installed by a dealer?Do you know where the inverter is? I’m looking all over the van but locate it.
Start at the beginning. Have you checked you are still getting mains power from the EHU supply socket? The lights and fridge could be working from the battery.Have blown the plug sockets in the van. Lights and fridge working on EHU but no sockets. All the fuses and breaker units seem to be OK.
By double you mean the large centre floor locker accessed internally?Where the inverter is - normally if fitted by someone with some brains it will be near the batteries to keep the 12v cable runs short, often in Carthagos in the double near the batteries.
Ones I have seen access via a locker door, my mates inverter is under the floor in the centre at the front a foot or two from the batteries (E-Line).By double you mean the large centre floor locker accessed internally?
Some inverters like the Waco have the relay built in.I'd agree with Lenny HB that it's related to the changeover relay that switches from mains to inverter automatically. This relay will probably be located either inside the Consumer Unit (the box with all the mains fuses/breakers) or in a separate box just near it. Most electrical problems in devices subject to vibration and damp are loose/bad connections rather than failed components.
