Durham's dad
Hello all
I've got a Dometic cf36 12 volt chest fridge/freezer which is really good and useful. It tucks under my single bed in the locker at the rear of the van. For most of the time it's worked fine, though thinking back we've had a mains hook up at many of the sites we've visited when it's been in use. However, we've recently been off grid and it's not been firing up. I know it'll cut out when the battery gets to a certain level. It's set to do that at about 10.3 volts but we've got 200 watts of solar and 220 amp hours of battery and I've not seen a voltage below 12.5 in all the time we've been away.
On returning home I've checked the voltage at the freezer plug and it has been about the same, perhaps .1 of a volt less than at the front of the van where the batteries are, reading 12.7 today.
I managed to contact Dometic via e mail and they suggested a power issue (stilted conversation really, not the same as speaking directly but anyway) so I took the freezer out and wired it, using it's lead alone, directly to my car battery and, Yes it works!
So my question is, why won't it work at the back of the van when there appears to be more than adequate voltage? Does amperage drop regardless of voltage over a distance?
It's a teaser!!
Thanks in anticipation...
It's a teaser!!
