ShiftZZ
How does that work?
I am just upgrading my security cameras, whilst I am happy with the ring setup I have a little niggle about them being jammed so I am installing IP based cameras. I have used a 4 port POE switch in my Garage I am using a power line plug to get the data back in to the home and all is working wellHow does that work?
You need to give more details as to your question sorry.How does that work?
Do you mean ’jammed’ as in blocked, or ‘jammed’ as in frozen picture (which I get on mine sometimes, possibly due to Wi-fi dropouts.......?I am just upgrading my security cameras, whilst I am happy with the ring setup I have a little niggle about them being jammed so I am installing IP based cameras. I have used a 4 port POE switch in my Garage I am using a power line plug to get the data back in to the home and all is working well
The 4 Port POE TP Link switch is about £13 cheaper than the equivalent NETGEAR switch and is very reliable (I have both). View attachment 467961 View attachment 467962
At a guess about 30 - 40 metresHow far from the NVR is the garage camera?
Leaving batteries aside a camera needs a supply and a data connection. If it's near a socket then you can plug it in and connect the data cable. Poe allows you to inject 12v(?) Into the data cable (cat5 or above) at source and split it out beside the camera saving a possibly long cable run. Not all cameras can do this.How does that work?
Have if been burgled about 14 months ago I went straight out and brought ring cameras, it was a bit of a knee jerk reaction as I normally do a bit of research they do work and as you say occasionally drop out. My concern is that a friend recently had a break in neither his or his neighbours picked up any activity and there was no recordings at the time they believe it happened. The thought is the cameras had been jammed (similar to a tracker being jammed). Two thoughts one is it was a ring system error or it may be a hammer but hand held jammers are not that powerful they could take out several houses at once, a bigger jammer would be needed.Do you mean ’jammed’ as in blocked, or ‘jammed’ as in frozen picture (which I get on mine sometimes, possibly due to Wi-fi dropouts.......?![]()
Ah ok but the POE switch is only 10 metersI don’t fit Uniview, but you should be fine at 30-40m with no power injection.
The cable type is important, make sure it’s 5e and copper, if your doing a few cameras buy cable on a reel and fit your own plugs.
OK I am not using the POE ports, you can do but this being an IP system and the data is going through my home ring main (240V) so my Broadband router is connected to a power line plug (left of picture)Uniview say their NVR's all have a poe range of 250m.
A power injector is used to provide power to a device when either your not using a POE switch or it is a heck of a long run and you happen to have a power source close to the device that can be powered by a ethernet power injectorLeaving batteries aside a camera needs a supply and a data connection. If it's near a socket then you can plug it in and connect the data cable. Poe allows you to inject 12v(?) Into the data cable (cat5 or above) at source and split it out beside the camera saving a possibly long cable run. Not all cameras can do this.
Yes, I did this last year when I installed a camera in a very remote location up may stairs. The poe allowed me to control the camera power supply and the LAN locally from the same easy access switch on the ground floor.A power injector is used to provide power to a device when either your not using a POE switch or it is a heck of a long run and you happen to have a power source close to the device that can be powered by a ethernet power injector
From a consumer perspective power line are fine in some homes they can be problematic so each person needs to check how something like a power line unit works, mine seem to be OK but understand some have issues.If your doing this for 1 camera which is extremely hard to get a cable to from the NVR that will work, but its an expensive and complicated method for multiple cameras, its also relies in the local network and will be data heavy.
Powerline adaptors can also be troublesome, for each camera you will loose a plug socket and will have wires everywhere.
I did a 7 camera system today, 1 mains lead, 8 cat5e cables, 1 HDMI, set up app on clients iPad and authorise my iPad (pro app) job done.
I agree about the cables no one wants to see them, and I guess that is one thing that is attractive about the WiFi Battery operated Ring Camera. I agree Cable runs look ugly who needs them!Although I'm fitting CCTV at the moment (along with Ubiquiti and draytek networks and Came access and gate systems) I can't claim to be an expert really.
I've done the courses and have certificates for the wall, but I run an International Events Company (or I did before Covid and hope do so again) but having done a number of offices and houses now I'm sure your system will work, but it seems a lot of extra effort and money.
Every job I do people don't want cables or kit on view, todays as I said was 7 cameras I previously set up their network and alarm system and added the cameras today and the only visible cables are from wall sockets to 3 PC's
Hope it all goes well.
