pedal lock on ebay............any good?
Looks a bit fiddly to fit and probably better doing it from outside with the door open.
I suppose for the price it should do the job.
Hi I bought a Clutch Lock as in the link below. Prefer the bright yellow and that it locks across more than just the clutch. Plus has a flashing light so a good visual deterrent.
But much prefer your price?. Would be interested to know what other think? is the one I bought really worth that much more?
Amazon product ASIN B074DW9PK7
Unless there's a hole drilled in the pedal I can't see what would stop you moving the lock up the pedal and laying it over.
You wouldn't have full range on the pedal but maybe enough to engage gear or definately press the brake if it was attached to it.
I have one of those cheap ones.
You can't just lift the pedal and slide off as others suggest.
Only fits the brake pedal well on an older Ducato.
Easier done standing outside the vehicle.
I like the visual deterrent but think your own hidden fuel pump kill switch is best.
many thanks all, iirc our 2017 fiat ducato based adria has thick pedal arms, will need to check that first :oops:
I purchased a Clutch Claw fully customisable to suit pedal arms thicknesses etc for a 2013 Autotrail (Fiat) changed the van to a 2017 A class Hymer again on a fiat fitted perfectly. Not cheap but nor is a moho, you get what you pay for my money my choice. ?
It could be described as looking a little micky mouse. £10 2 minutes with cutter. As previously suggested cut pedal add molegrips.
£100 for a cluch clAw is where i spent my money. A pedal box has been described as a better product £150, where to stop spending. 4 yellows £270 plus alarm ?.?...?
Dont forget to use them.
I never suggested you could slide it OFF.
But just looking at it there nothing to stop you sliding it UP the pedal then laying it flat unless there's a hole drilled in the pedal to receive the padlocks bolt.
i guess if they want it theyll cut anything off............
As the pedal arms are plastic on later vans, it's unlikely to be any metal anti-theft devices they'll be cutting!
