Parts departments
NOTTINGHAM
Autotrail Savannah
Almost a Newbie but not quite now.
Just wondering if Auto-trail part departments are trained by the same as those in the Royal Navy.
I enquired today about a problem I have noticed with the Seitz blind on my Autotrail Savannah. I noticed it has melted due to the heat from the rear gas burner on the stove. I also mentioned as an aside how this sort of dangerous fault could be designed into a motorhome and that we no longer boil the kettle on the rear gas ring as we would like not to have our motorhome burn down in front of us.
I posted a picture:
to prove my point and fears of a fire, (this is the rear of the cooker hob) along with the year of manufacture (2010) and model.
About 5 minutes later I received a request for Chassis number or Build number.
Do they change the specification of these motor-homes mid run so next week we put the window at the rear ? or am I just being cynical.
I would have thought any fully trained parts department member would be able to pull up the spec's on microfiche and say "ah, that is the part he is wanting". :Grin: :Grin:
or is it me ???
Auto-Trail.
Do actually work from the Build numbers in the parts dept l can confirm this from personal experience.
Cliff
Can you pull back a bit with your camera please, I cant get a good view perspective of what you are trying to describe..Thanks
Yes I would have thought that any spares dept would have at least an on-line schematic diagram of every part along with part numbers etc for model & year of manufacture.
I just hope and prey your parts are still available, short runs are also a worry.
Good luck
Les
Good luck
Les
Thanks for the response,, pity Autotrail cannot respond better,, Just had a missive saying they only stock complete blinds and to try Dometic direct for spares ?? Just hope nothing else breaks.
Here is a picture of whole area showing cooker and window. Problem is in bottom, right hand corner:
