ShiftZZ
Any recommendations as to regards which paint?
You could always get a quote but I would sit down first!!!!Johnsons or Leyland is quite good but if you want top notch try these people.
Polycote | Maintenance Made Easy
Welcome to Polycote, the UK’s leading manufacturer and supplier of industrial floor paints, coatings, concrete floor repair materials and maintenance products. Shop online now.www.polycote.com
Are we talking about a van garage or a concrete floor garage?Any recommendations as to regards which paint?
Garage, house,Are we talking about a van garage or a concrete floor garage?
Also make sure you clean the floor thoroughly. I've done it using Fairy Liquid and a scrubbing brush and then a hose. Then using a two pac.Two pack epoxy paint, for a good job
I would say epoxy is your best bet if you want a long lasting tough coating. It bonds far better than any paint can that I am aware of?Garage, house,
How old is he ? Then your know how long it has to last. HahaDon’t paint a garage floor. It won’t last. Expoxy resin it. That is what you get in the main dealer type workshops.
Wish I'd known it came with those lifts .ShiftZZ
I own a garage, mot station and it sees a lot of vehicles over it on a daily basis, there is only one paint i will use now and its made by Crown and is called "Epimac" it is superb.
We paint the floor once a year and have been using this paint for over 20 years and it with stands everything spilt on it, petrol, diesel, brake fluid etc and DOES NOT PEEL
Ideally you need to put it on a clean concrete floor and 1st coat needs to be thinned down so it has the consistancy of water so is soaks into the concrete to create a great key. Then 2 more coats and your done then it will lool like this
