mitzimad
- Jan 28, 2008
- 10,327
- 18,889
- Renalt burstner
- 7 years campers before that
is there a way to tell which direction electricity is flowing through a wire?
AC or DC current?is there a way to tell which direction electricity is flowing through a wire?
The direction of flow was chosen arbitrarily before the nature of electricity and the characteristics of the charge carriers was known. It was a 50/50 guess, but unfortunately it was wrong. Charge carriers in metals are negative, and flow from negative to positive. But to this day, engineers and scientists still always describe current flow as moving from positive to negative.Convention uses positive to negative. In reality it's from negative to positive.
as a plumber by trade i think of all electricity as flow and returnTo detect the direction the current is flowing you will have to use a multimeter as an ammeter as described above. Current can flow in both directions into the positive terminal of a battery depending on whether it is being charged or discharged. Think of it like water in a tap - when you open the tap water flows out (discharge) but if you blow hard enough you can force the water back in just like charging a battery.![]()
not if there is a battery either end is a b2b wireCut the wire, then see which one has power to it then that’s the way it’s coming.Then connector block the wire.
And that is why measuring with a multimeter/ampmeter will give you the wrong answer as they are set up for convention not to give you the truth.Convention uses positive to negative. In reality it's from negative to positive.
Which would mean it’s coming 2 ways.wire
If you wire up the B2B exactly as Sterling recommend with the cables going to the battery terminals any on board battery monitor you have will not show the true charging current.maybe i should elaberate i inherited a b2b charger i spoke to sterling and wired it upo and it showed 10 amps discharge on my screen in the van spoke to sterling again and got the opposite advice re wiring so i reversed it and then it showed 6 amps of discharge so i dissed it and forgot about it with winter coming im thinking of reconnecting
i handt thought that an ampmeter will show positive or minus so will try that
