- Aug 16, 2021
- 31
- 44
- Adria sunliving lido
Following your sage advice in response to my previous post I have just had the Votronic 250 charge controller to connect my two 120W solar panels to my 2x85Ahr Gel batteries. One of the attractions was the Votronic's ability to trickle charge the starter batter as well through the EBL 208S. I previously obtained the Mate'n'Lok plug (thanks Lenny B from a previous post) for the EBL solar panel connections and have prewired the three cables, 2 positives, for the leisure and starter batteries and a common(?) negative.
I plug in and the three cables are now ready for connection to the Votronic which arrived in the post today so now to plug everything together. To make absolutely sure, I checked the wiring diagram for the EBL (thanks Spriddler from a previous post). To my surprise the connections to the solar panel regulator do not show any connection to the starter battery (see diagram below taken from the Schaudt operating instructions). So I put the voltmeter on the different cables expecting the central ('starter battery') cable to show zero - unconnected - but find both positives give me 12.5v against the negative. Looks like the central cable is connect to a battery.
Can I do any harm by connecting the Votronic as though I hadn't seen this pesky diagram? (I know I appear a bit risk averse, that's because I am!)
