oil pump (1 Viewer)
hay
blackisle
hi top
3yrs
I have an old fiat ducato 1992 1.9td I need information on oil pump where can I get a replacement
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
If you want to pm me vehicle reg I can check my suppliers for you
Seems a strange request does that,unless your doing an engine rebuild I cant see the need of one, are you trying to cure an oil pressure problem if so I suspect your on the wrong track
G
Jan 28, 2008
10,121
18,387
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if you have low oil pressure its more likely to be worn bearings than an oil pump, in my experience they either work or it all goes bang
H
hay
blackisle
hi top
3yrs
oilpump
Seems a strange request does that,unless your doing an engine rebuild I cant see the need of one, are yaou trying to cure an oil pressure problem if so I suspect your on the wrong track
G
we are rebuilding my engine and found that the oil pump has a problem the gear is thicker than the casting when plate is fixed it jams gear should there be a gasket it would need to be 8thou thick to give clearance my reg is k481cfs gratefull for any help.
H
hay
blackisle
hi top
3yrs
oilpump
the pump was dismantled by someone else not available the gear is deeper than the casting when the cover plate is fitted it jams the gear should there be a gasket if so what material should be used regards j
