HI could use a bit of advice on servicing i done the oil and filter a year ago and i have only covered about 2 thousand miles since would you do it again now, or leave it for a few more miles ,,thanks oh its a fiat based ducato 150bhp 2018
Thanks..I get it ordered...Yes, low mileage means it’s even more imperative the oil is changed. Condensation can build up in engines not used much and dilute the oil.
Quick and easy job and less than £50.![]()
hi what oil do you use and where do i get it for £50 with filter ,,Yes, low mileage means it’s even more imperative the oil is changed. Condensation can build up in engines not used much and dilute the oil.
This^^^^^^^^Yes, low mileage means it’s even more imperative the oil is changed
oh ok thought he had somewhere special ,,looking more like £70 now ,,that's covid for you ,,ehUsually online for best price, euro car parts or gsf car parts delivered or local pick up.
I think the 50 pounds was an indication it's not an expensive job to diy, rather than a calculated quotation.
hi again do you think even if its long journeys ie,,2 hour trips ,,i did ,,i dont do start,, stop journeys it still needs changing ,,?Yes, low mileage means it’s even more imperative the oil is changed. Condensation can build up in engines not used much and dilute the oil.
Sorry, I do it myself. Couldn’t tell you which oil, I just get whatever my local motor factor has in.hi what oil do you use and where do i get it for £50 with filter ,,
Condensation cannot dilute oil. Oil and water don't mix. Short trips can cause condensation in the engine which would show asmayonaise in the filler cap. It would boil off on a longer trip.Yes, low mileage means it’s even more imperative the oil is changed. Condensation can build up in engines not used much and dilute the oil.
Okay, it’s not my area of expertise but the Haynes manual says it becomes diluted.Condensation cannot dilute oil. Oil and water don't mix. Short trips can cause condensation in the engine which would show asmayonaise in the filler cap. It would boil off on a longer trip.
At 12 months and 2000 miles the oil will be as new and not worth changing. Your would do it more good taking it for a decent drive.
Diluted by diesel maybe in time but not 1 year or 2000 miles. You would notice dilution as the oil level would rise or the oil change warning would come on. Plus its only caused by forced DPF regenerations which would not happen for many thousands of miles.Okay, it’s not my area of expertise but the Haynes manual says it becomes diluted.
Either way, if in doubt, it gets changed every 6 months and 2000 miles a year isn’t a well used hot engine in most circumstances.
John
That sound like good advice think I leave it till next year...got enough to spend on cam belt this year...I emailed Castrol tech services as I had read on their website that the oil was good for 20000 / 2 years. I explained it was for a MH which did 5000 miles per year. Would they advise 2 year oil change or more frequent. They said 2 year was fine.
Now you might say they missed a chance to sell more oil, or they were being genuine in their tech advice, your choice.
Yes but is c3 comparable? most these days need acea 4 or 5Fully Synthetic 5W/30 C3 engine
That is only for acea 2 or 3 yours probably requires at least acea 4 more likely 5.I'm happy to use 5/30.
0w is only Fiat's attempt a low emissions at start up and another attempt at selling a very expensive oil.
I change mine every two years and 16,000 miles.
apparently yes this is the oil recommended by opie oils ,,Yes but is c3 comparable? most these days need acea 4 or 5
They stock two fully synthetic oils. One is basically for Fiat/BMW and another one for Ford.That is only for acea 2 or 3 yours probably requires at least acea 4 more likely 5.
no neither could i that's why i put the c3 in last year ,,and it will be staying in till i come back from France in July ,,that will be that will be 19 months,,and about 3000 miles ,,ishIts a mine field but I cant find any recommended oil at acea 4 or 5
Rock Oil Synthesis F 5W-30 Engine Oil » Tyne and Wear Oils
Rock Oil Synthesis F 5W-30 Engine Oil Rock Oil Synthesis F 5W-30 fully synthetic engine oil is a premium engine oil specifically for use in Ford and Jaguar Land Rover vehicles.twoils.co.uk
Synthesis Sport 5W-30 - Rock Oil
rockoil.co.uk
Selenia WR Forward 0W-30 Euro 6 engine oil for the new Fiat Ducato motorhome engines
Selenia WR (Wide Range) 0W-30 is the new fully synthetic engine oil specially made by Fiat for diesel engines with Euro 6 standards.
The viscosity grade of 0W-30 has a direct influence on the fuel consumption and reduces it, thereby reducing the production of CO2.
Original Fiat engine oil offers the following advantages
Technical specifications
- minimizes fuel consumption
- High thermal stability
- Increased engine protection through the use of the original oil
- SAE 0W-30
- ACEA C2
- Official Fiat approval: Fiat 9.55535-DS1
Selenia WR Pure Energy 5W-30 engine oil Euro 5 emission standard for Fiat Ducato engines
Selenia WR (Wide Range) Pure Energy 5W-30 is a fully synthetic motor oil that meets the requirements of Euro 5 diesel engines. The ACEA-C2 specification certifies the low ash content. This property ensures that the anti-particulate filter is protected against the combustion residue. This prevents the soot particle filter from clogging.
Technical specifications:
- It strengthens the protection of the engine
- It increases the fuel economy of the engine
- low ash content, which protects the efficiency of the diesel engine
- SAE 5W-30
- ACEA C2
- Official Fiat approval: Fiat 9.55535-S1
For the first five years our 2014 Ducato based was serviced by a Fiat Professional dealer and they used Fuchs Titan.In my euro6 Ducato i use
Fuchs TITAN GT1 Pro 2312 0w-30 Premium Performance Fuel Economy Engine Oil This complies with the requirements of the Fiat spec.
I also change every year especialy if low mileage. If you exceeded 10000 pa then Fiat advice is every 2 years. The effect of condensation in the oil is to oxidize the additives and create an acid environment, even more so with high Sulphur fuels. A regular blast up the motorway helps drive away the water preventing acid generation. Another contaminant that is very detrimental to oil is ethelyne glycol, anti freeze, however Modern antifreezes do not contain ethylene glycol any more, but OAT based (not porridge oats). Short start stop runs or long idling are the most detrimental to oils and engines with diesel dilution and varnishing.
-Broken Link Removed-
