OBD 2 Port - Burstner Aviano
Yorkshire
Does anybody know if the OBD 2 Port is located under the drivers wheel on a Burstner Aviano i727? it is on a Fiat Ducato base.
Thanx
Ours, fiat, is in fuse box by drivers knee.
Need to remove 2 phillips screws to remove panel. Probably a cover on obd port ,
Don't know if this helps but mine is a Peugeot base and it's located in the fuse area to the right of the steering wheel and had a yellow plastic push in protector top.I didn't recognise it at first because of the yellow top .
Yes its under the steering wheel by your right knee. Two screws and remove the panel. OBDII port is covered by a plastic guard.
TheBig1 did a post on a OBD lock that shows the location.
