feetnpaws1
- Jun 12, 2022
- 5
- 0
- itenio SN700
It will be with the circuit breakers, usually very similar looking with a little test button on itHi, checked the EHU, that’s ok, fuzes fine but still no 240v inside, is there a RCD in the Itenio and if so where is it
You must have a separate 230v consumer unit somewhere.The only breaker is a standard breaker, and that’s in the back garage. RCD breakers look different
Do you have a picture of the MCB? Does it have a 'Test' button on it, maybe it's an RCBO, which is a combined RCD and MCB.Yep , the MCB is in the garage, a breaker with a number if fuzes. I was talking about a RCD which would have tripped to stop power coming in through the EHU
