Hi new to having a motor home it has a reversing camera but not working where would it pick up power from monitor is mounted on dash it is a fiat bessacarr.
There must be a fuse somewhere, I’d check the wires on the battery terminals as some fitters just go straight there rather than going into the vans own fuse box . I think mine is wired that way as there are various additional single wires attached to the terminal on mine. It may be that the monitor is kaput so you wouldn’t know if the camera is working or not. Is there a detachable link on the rear of the monitor which you could temp power up ? That way you’ll know if it works or not . Good luck .
