No Gas (2 Viewers)
Melvin
230
182
Coach built
On & off since 1974
Started recommissioning after being SORN for a couple of months.Ive found I haven't any gas at the cooker,I've change bottles,no good.When the gas leaves the bottle there is an inline press button valve then the regulator which has a push type valve in the body of it.
Is there a set sequence for setting up these vales?
53,485
150,255
Not really, need the gas on and the green buttons pushed in on the hose first otherwise there will be no pressure to hold the safety valve in the regulator on. Probably the regulator gummed up with oily residue. Sounds like you may need a new regulator.
Melvin
Melvin
230
182
Coach built
On & off since 1974
It seems to be a common problem especially the Truma ones . The mh is going in for its first hab check next week hopefully it will be sorted out for me as it's just about a year old .
