No 12v power in habitation area (3 Viewers)
Sep 21, 2013
226
241
Isle of Wight
since Apr 2013
I have a Y plate Hobby 600 on a Ducati chassis.
About 2weeks ago all was fine and everything was working ok. Today I went into it and there's no 12v to the lights, water pump, TV booster, but the fridge ignition works and the fridge runs on 12v when the engine is running. There is also 12v to the TV which runs direct to the TV via a separate switch direct from the leisure battery. All 4 circuit breakers seem fine.
The engine starts perfectly and even when running there is no 12 volt to the hab area. At present I cant get it onto mains to see what happens then until the weekend.
The only fuse in the engine compartment I can find seems fine.
Batteries show about 13 volts on the display voltmeters and the ammeter is dead centre with no charge or discharge.
Anybody any ideas what could be wrong.
vectian
Sep 21, 2013
226
241
Isle of Wight
since Apr 2013
I've put it on mains hook up and the control panel shows the leisure batteries are fully charged.
The fuses on the leisure batteries are intact. Ive taken the control panel off and there doesn't appear to be any 12 volt feeds to be live on it.
Feb 8, 2014
1,662
4,673
Sheffield
Eldis Majestic 115
Vans and tugs since mid 70's
The only advice I can offer is negative in that the habitation area should be isolated apart from the fridge when the engine is running.
vectian
Sep 21, 2013
226
241
Isle of Wight
since Apr 2013
Thanks vin0114
Spent most of day trying to sort. After having to remove both front captains seats to get to leisure battery and what I thought was a battery charger I find power going into the box but nothing going to the control panel. A very helpful Paul at Themotorhomedepot says it is likely this big black box under the seat thats the problem. Sent him pics to identify which particular unit it is for the age and model. Has anyone any idea what its called and where I might source one and the rough price of it
vectian
Sep 21, 2013
226
241
Isle of Wight
since Apr 2013
Can you post pictures so we can see what it is
PICT0006.JPG Here's the offending object, the first pic shows it with the top of the box removed to show the workings, mainly a transformer, circuit board with 6 or 7 relays. The second is the label from the front.
There's power on two of the leads from leisure battery and vehicle battery and nothing out of it
Sep 23, 2013
2,586
8,837
Lincs
Globecar Campscout
Apuljack Engineering also come recommended (by eddievanbitz, no less, among others).
denisejoe
5,625
12,055
Warden isle of sheppy
everything in the back of our Euramobil works with the engine on. Just need to arrange some straps so that Denise can cook our dinner while we're going along, LOL! Already got a seatbelt on the loo.
joe
Jul 5, 2013
11,731
13,711
Thanks @denisejoe, didn't know that and amazed that this is a just a UK requirement when every other restraint seems to originate from EU directives.
AFAIK this one comes from some bright spark in the NCC (group that represents UK caravan and motorhome manufacturers). Daft idea. AFAIK none of the European motorhomes have this restriction - the Adria I had before and my present Hymer certainly don't.
