New Battery Problem
Southport
since 2008
Since changing the Battery in our 2015 Fiat base Hymer I now have a number of warning lights that are on all the time.
Airbag, Faint Battery Light , Mileage is flashing, Low Battery reading - even though a new battery. It starts & runs just fine. Any advice much appreciated. Maybe its a dealer plug in to reset ??
Did the alternator lead come loose from it somehow on replacement
or maybe fuse if it had one
edit: just found this
This may help?
Thanks for the replies, but its not just the Odometer - I have a whole host of warning lights that are on all the time
Pretty all the leads are secure. I do wonder if this is caused by the period between removing old battery and putting the new one in, ie: a time when all the engine management systems have no power ??
The red battery light usually means that the alternator is not charging the battery properly. You really need to check that you're getting around 14.2v at the battery with the engine running.
