Need to Replace my Engine Battery - Recommendations? (1 Viewer)
Dec 5, 2013
317
249
Somerset
I bough mine from Halfords in 2018 (still going strong) it has a lifetime guarantee!
It is for my 1999 B644 2.8 td, here are the details:
Product CodeProductQtyTotal
177463HAL BATT 019 LIFETIME1£136.00
VAT Amount£22.67
Total£136.00
Visa Debit
Woody44
Bessacarr E789
I have a number of Vehicles that don't get used every day, motorhome, forklift, jcb loader, etc, I have had no end of trouble with the yuasa battries, i now fit Bosch, slightly more expensive, but fit and forget, now every thing starts even after weeks of no use.
Tip for Motorhome storage is if out side fit solar panels , if inside plugin, i leave heater on lowest in mine.
11,932
9,097
VAT Amount£22.67
Total£136.00
Visa Debit
Lifetime guarantee. What is the expected lifetime ? Only good for how ever long manufacturers say the LT is 😉
Mar 3, 2019
12
5
Shropshire
Boxer PVC
Since 2014
My battery is dead, tried to recover it but it will not take a charge above 11.4 volts. It has been deeply discharged whilst in storage. Tried all of the tricks (other good battery in parallel, changing charging rates etc) but I'm afraid its gone. it's a
Banner 250/334 12v 95Ah 680CCA Car Battery (P95 05) (250/334)​
Anyone have recommendations for a good quality replacement at a reasonable price? Looking at Exide at the moment with 800CCA rather than the Banner 680CCA.
TIA
Tayna batteries (Web). Seem
to be the best price I could find for quality batteries. Have replaced leisure and starting batteries from them.
All EFB, great service, about £6.00 delivery I think.
Steveg
Oct 8, 2016
229
372
Tunbridge Wells
Bailey 75-2
I'm a newbie
Got ours from here but they are currently out of stock
The other option I looked at was here
Both more expensive than Lenny's £105
Can I ask where you got it please Lenny - cheapest I can find is £119.99?
Tayna charge delivery on top of battery price. Battery Megastore is free del on orders over £30. Probably works out very similar.
53,495
150,310
Tayna will give a 5% discount if you sign up to their newsletter also if buying more than one battery phone them and they will just charge one lot of carriage.
I normally buy from Tayna but this time Halfords were cheaper and more convenient.
Gellyneck
9,247
18,339
More than toes wet now!
The price I quoted in post #10 included the delivery cost from Tayna. Battery Megastore is, as noted, out of stock.
Sep 9, 2019
857
1,904
Runcorn
Autotrail Apache 632
Since Sept 2019
Apply for a Halfords Trade Card, you get 10% off service parts and tools.
May 22, 2018
194
210
Oxfordshire
Hymer Exsis I 678
Since 2016
I had a new 95AH 800CCA EN Battery, including fitting for £107 + Vat.
This was done by Haynes in Wallingford. 01491 836097. There was no problems with having to reset the radio & clock etc. It can save a lot of hassle & back ache to get someone else to fit it. They also did the first service at the same time for a very competitive price.
You may find your local garage turns out to be competitive if you ask around. By the way our local Fiat main agent estimated £250 to fit a engine battery.
Gaza1515
35
35
Accrington
Geist 710
TIA
Hi, just bought this one for my moho. £95.00 delivered. https://www.alpha-batteries.co.uk/019-nordstar-car-battery/
dbailey2
70
46
ESSEX
DETHLEFFS ADVANTAGE T6511
Yuasa batteries use ca/ca technology and from what I read they require charging at a higher voltage in the order of 16V - 16.5V. As most vehicle alternators regulate the charging voltage to about 15V does anyone foresee any possible charging issues that may degrade the battery performance?
53,495
150,310
I thought moist of the Bosch & Varta batteries are calcium also.
Yuasa give the charge voltage as 14.4 to 14.8v.
Oct 8, 2016
229
372
Tunbridge Wells
Bailey 75-2
I'm a newbie
Both more expensive than Lenny's £105 though.
Tayna give 10% to CMC members.
Now that is worth noting. Tayna do really keen prices anyway and an additional 10% may just swing it for me as opposed to waiting for my Halfords Trade card with associated discounts. Hence the value of these forums. I’m a member of CMC (CAMC) and that would have slipped right past me. Thanks!
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
I have just replaced my starter battery with a Yuasa YBX7019 100AH 850A EFB
It came from Tayna Batteries I bough it through Amazon and cost £112.45 with free delivery.
The same battery on Tanya's own web site is listed at £119.99 plus £9.18 delivery.
Amazon saved me £16.72. It was Tanya listed it on Amazon as two day delivery, it arrived the next day.
dbailey2
70
46
ESSEX
This is the article I was referring to regarding CA batteries needing a higher charging voltage.
Calcium Battery Charging​
The problem is that a special battery charger is needed for a calcium battery, Master is ideal Watt BOT-30 with artificial intelligence. Also, this charger should produce a charge voltage of 16.1-16.5 V. In this case, you can charge the battery "CA", "CA/CA" up to 100 percent. If your charger is capable of delivering a maximum voltage of 14.8 V, and then the electronics are disconnected, then the battery will fill up by only 45 to 50 percent, if there is a 15.5 V limit, then 70 to 80. Such indicators will never help to achieve electrolyte density at 1.27 g/cm³
Therefore, first of all, you need to find a charge that can produce a voltage of 16.1-16.5 V. Conventional devices cannot do this.
At this stage, you may have a question, if such a large voltage is needed for charging, how does the generator handle this?
Indeed, the generators of even the cars of the last years of production do not give more than 15 V, but in practice the generator simply does not allow such a battery to discharge.
53,495
150,310
If you read Yuasa info they say they have increased the chare range up to 14.8v to cope with Ford vehicles charging voltage as they use Silver Calcium batteries.
I think I would go with Yuasa figures as they designed the battery rather than a general article. Also they are fitted as OEM batteries worldwide.
