Nc10 on XP trying to connect to Tablet t585 (1 Viewer)
Destination Unknown
398
835
Anywhere and everywhere
American A Class
Not Long Enough...!!
Hoping a tech person can come up with the answer.
We are using a Samsung tablet t585 as a hotspot, Our Samsung nc10 on XP can see the WiFi available but will not connect.
Some one said it could be a security issue on the tablet being newer than the Nc10. Have looked on interweb and the info some sites are saying we can't seem to work out how to do it.
So it' down the technical assistance of MHF members
Lenny HB
53,448
150,060
On the coast in West Sussex
Hymer B678 DL
Try a different sim in the tablet, not all networks work with hotspots on all devices. Had the problem on my last phone couldn't connect to it with a plusnet sim in it, sorted it by going into debugging mode and download some code to it.
Also does your contract allow thering..
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Since 2015
As @Lenny HB says you are going to have to try a process of deduction. I.e.
Will it connect to a normal WiFi signal?
Can you try it on another hotspot?
Does another device connect to the hotspot your NC10 won't connect too etc.
I use a NC10 but with Linux installed and never had a problem although it is getting a little slow!
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I'm taking a guess a WAP, WAP2 sort of thing, the protection level.
Old netbook might be limited to WAP and new tablet requires WAP2.
See what you can find poking around under Security / Protection.
Destination Unknown
Destination Unknown
398
835
American A Class
Thanks All.
It' a Wap problem, if I set it to Open then the computer connects, but password it will not.
Just got to make sure nobody has connected while Chris is on.
Lenny HB
53,448
150,060
Hymer B678 DL
Thanks All.
It you can't get Wep to work, you will just a case of selecting the right type of encryption that suits both devices. In the meantime you could turn off the SSID.
Gellyneck
9,235
18,212
Scotland
More than toes wet now!
Given the probable age of the netbook guess it should be WPA2 compatible.
Have you checked your hotspot is configured as WPA2 (AES or TKIP) and likewise for the netbook?
