R
Robert Clark
Thanks Michael - just double checkingT
Robert, your Victron inverter/charger has a Lithium charging profile, which can be adapted through VE config.
I have a Relion RB100. I charge it at 14.6v and have set the maintenance voltage at 13.8v. This seems to be working very well and is my understanding of what Relion recommend. I don’t think you need to worry about cell balancing, I believe the BMS takes care of this. Relion also say:I'm thinking of using Relion RB100's which only give two voltages
Charge voltage 14.2 - 14.6v
Balancing voltage 14.4v
Ok those are not cells those are batteries with built in BMS. Different kettle of fish. Ignore what I said and listen to others on hereI'm thinking of using Relion RB100's which only give two voltages
I initially charged my cells to 3.65v per cell (14.6v) to balance them and now have it all set at 3.55v (14.2v).
This was on the recommendation on a technician at EV Power who advised the cells would have a better life span at the lower voltage.
No idea on the Relion batteries or other complete solutions I'm afraid.
Not sure which Elekroblock you have but with my 29 Udo Lang at Schaudt advised keeping it for eveything except charging. He suggested simply removing the 20 amp charging fuse from it and wiring my LiFePO4 friendly mains charger directly to the battery. For the battery to battery charger it was just a matter of intercepting the engine battery feed before it entered the Elektroblock. He said the advantage was the Elektroblock could still trickle charge the engine battery when on mains and the mains connection light would still function.
