- Mar 28, 2019
- 30
- 2
- Bessacarr E795. 2004 on
- Since 2018
As above unless u add the lesure battery is this comon on all or just certain M/H
What exactly do you mean by connect?That's the thing as soon as I connect lesure battery van starts fine
Love that! My kind of answer! Like you ....I think its the engine battery being scuppered! Im guessing as soon as the jump leads go on...all will be ok.Take the leisure battery out of the equation. Chuck it in the shed.
Ok but in the fiat manual it says in thick black letters don't jump start this vechile any way you can't get cables on the + side of battery
Not necessarily our cranking voltage has always been low on the car, sometimes it was 7.9v ? it always whipped the engine over so I ignored it... Anyway had a new battery this week because it started to lose charge (with no drain), and guess what? The cranking voltage is too low again ?With David here....Engine starter battery at fault! Multimeter...What does it read when put across the engine battery prior to starting? What des it read when attempting start up? If it drops below 9 volts.....its buggered!
Kev
No, that’s Bump starting!?doesnt jump starting refer to physically pushing the vehicle and 'jumping it into gear to start'.
It seems that your leisure battery is already linked with your starter battery somehow,this is unusual,what make of motorhome is it. It may have had a battery link switch fitted which would allow you to start the engine even if the engine start battery was faulty or flat for another reason.That's the thing as soon as I connect lesure battery van starts fine and no alarm fault also when I lay up van I disconnect cab earth to save flattening cab battery
The Fiat Ducato 2004 model doesn't have these points/fixings...you have to connect to the engine battery terminals.If it's Ducato, under the bonnet are 2 points that you can jump start it from { POS & NEG } without having to move the large grey plastic cover by the the passenger's feet to access the engine battery in the foot well.
If you can get a car or a truck to fire up with 7.9 volts........You have found the Holy Grail!Not necessarily our cranking voltage has always been low on the car, sometimes it was 7.9v ? it always whipped the engine over so I ignored it... Anyway had a new battery this week because it started to lose charge (with no drain), and guess what? The cranking voltage is too low again ?
That's BUMP starting.doesnt jump starting refer to physically pushing the vehicle and 'jumping it into gear to start'. using another battery isnt doing anything other than putting a new battery on but connecting it temporarily?
It is impossible to fire up any truck with 8 volts at the battery ! Sorry but it's true. What was you reading when it was connected up ? A crank test will drawer a massive amount out of a full battery at start up. If you only have 8 volts available....its impossible honest. Im guessing a misunderstanding of a reading here ?
Check the chart below...it may help a little
Looking at your test...The initial turn of the key and the starter motor engaging with the flywheel is 8 volts ish. It then turns and increases in power yes? Indicating one of three things. 1) Starter fault 2) Battery incorrect CCA and incorrect size 3) Battery not fully charged or fault on earth
