Jim
Ringleader
This thread is for the general discussion of the Article Motorhome Toilets.
Black tank every time for me.
Craig
Think things have change a bit since then, have done about 7k around Europe since buying my new van and not had any problems dumping the black tank.I don't miss mine. I liked the size of it. However, there just isn't the infrastructure for emptying them. I used to pump out using a layflat hose. That was pretty grim compared to emptying a cassette and I could only really do that at home. Continental campsites are particularly bad, with the "chemique" typically being part of the shower block, about 20m from the nearest tarmac.
My limited European language ability doesn't run to asking for the locations of suitable manhole covers to remove.
We’ve had USRVs for over 12 years and have never had a problem emptying in the uk or Europe.I don't miss mine. I liked the size of it. However, there just isn't the infrastructure for emptying them. I used to pump out using a layflat hose. That was pretty grim compared to emptying a cassette and I could only really do that at home. Continental campsites are particularly bad, with the "chemique" typically being part of the shower block, about 20m from the nearest tarmac.
My Thetford cassette leaks when i stand it on end to wheel to dump. Can you remind replace the seals ?
The Thetford seals aren’t cheap but copies are available- if you feel lucky
I'm not the queezy type but I would always buy a new cassette if ever I bought a used van for exactly the reasons you discovered.I also discovered that the previous owner... etc
Hi.a snakehipped 72kgs!!! (11.5stone)
Hi.
There you have it.... "snakehipped 72kgs!!! ( 11.5 stone ) Thats the price you pay for being thus.... Look on Youtube. There are several articles on how "snakehipped 72 kgs !!! (11.5 stone ) can use the Thetford toilet noiselessly. Hope this helps.
Tea Bag.
Silicon spray no touchy needed but then I ain't no snowflake and I've been in worse s**t than human waste when I worked for a living, that's the trouble with the modern generation everything has to be sterilised out of existence before they will go near it and wonder why they have no immune systemAnyone use olive oil to lubricate the blade?
Why pee before openng the flap, you can't be that desperate surely.Yes I agree, there must be a better way. Assuming it will always be some form of cassette, the problem is emptying it. How heavy will it be, how far do you have to take it? Hate turning it upside-down and pushing the vent button which always seems to dribble a little. Also worried when desperate for a wee, I pee before opening the flap, is it leaking past the cassette seal, when did I last apply silicon spray? Black tanks seem heavy and have their own problems. I have to say Thetford have come up with a wonderful product my feeble brain cannot improve.
Can you give a link to the small tank?carry a tank, plus a small black emergency tank (£15).
Never had any reason to dump anywhere we shouldn't in 20 years
I’ve heard it called lots of things but never a BladeAnyone use olive oil to lubricate the blade?
