Mercedes code resetter needed, must be really easy to use (1 Viewer)
andy63
4,672
15,018
south shields
since 1990
Oi you two, I am here as well you know
Sorry:xgrin:..
if not failed not sure what they will be looking at / for :)
That's been mentioned and pointed out to me in a previous post that the codes clear and reset after you shut down and restart... I'm not sure...
All I know is I've had codes stored without a light been on.. Some of them most probably relating to work I was doing and forgetting to reconnect something...
All I'm saying is ring.... let someone who knows tell you..
Look you've got me rambling again...:xgrin:
Andy..
DavidG58
Feb 24, 2013
13,109
101,579
Bolsover, Derbyshire
Hymer S800
not long enough
Sorry:xgrin:..
Andy..
I promise to call someone next week, you are right the codes are stored, unless wiped by one of the scanner things that I have just bought :) the issue seems to be interrelated between sensors, just need to find the right one to change first time hopefully (y)
or just drive it till it busts, now here I am going back round in the same old loop again :D
you worry too much for everybody Andy, but your concerns are appreciated (y)
Aug 18, 2014
23,857
134,484
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yes the codes stay recorded even when it resets by turning ignition on/off. Fords are the same. I fund there was no need to stop in the end . just turn off & back
on ,engine fired ,still in gear .:xlaugh: carry on
DavidG58
Feb 24, 2013
13,109
101,579
Hymer S800
not long enough
A little more exciting to try that with a full auto though :D:D
11,939
9,123
Oi you two, I am here as well you know,
Terry you said your man needed about 2 months notice to get in, I need far more spontaneous reaction than that :D
Andy, problem we really have is getting it to the workshop in a failed state, if not failed not sure what they will be looking at / for :)
It was more than two months ago :xgrin: and he is not my man only used him once when all else failed he found the fault for £60 quid =money well spent :xgrin:
11,939
9,123
Try holding it in second gear and thrashing it down the m/w for 20 mins :xgrin:that may clear it's brain or break it :xrofl::xsmile:either way it could produce a result :xgrin:
You can always borrow my new trouble free van David :xwink:----you know I MEAN THAT :xThumb:
terry
canopus
6,142
10,279
rural Lincolnshire
Carado CV640 Pro
We had a fault on our 2.7 Sprinter, ironically whilst waiting to go in to the MOT bay at Nottingham City Council Transport depot. The place is full of HGV mechanics as this is where the councils fleet of vehicles is maintained. A guy in overalls came over and had a look under the bonnet. Bear in mind Id just driven there 20 minutes before, the guy said it was probably an dodgy injector. We managed to start the van again and continued with the MOT which ended as a fail due to rear brakes needing replacing. Took the van straight from the MOT place straight round to Mertrux who we had used before. They did the brakes and sorted out the alleged injector fault ----- which turned out to be a faulty crankshaft positioning sensor. The van has never missed beat since - he says touching wood.
As stated previously , there are some features on Mercs which only Mercedes dealers can pinpoint and subsequently fix. Get yourself booked in to one and stop fannying about.
andy63
4,672
15,018
south shields
since 1990
Another little point worth remembering with the scanner/code reader...
What codes are you actually looking at..
Your vehicle is most probably obd11 compliant (think commercials had to be from 2007 )and a scanner will be able to look at those codes... but that's not the same as manufacture specific codes... The reader would have to have some manufacturer specific software to read those codes.. and it might again that's my thinking and a point worth checking....
I look forward to hearing what a good diagnostic place has to say.. may come to nothing but worth a try..
That's where the scope comes in... takes the guesswork out of checking suspected faulty sensors or actuators.
And may be possible to have it running under live conditions to catch even an intermittent fault..
Andy.
rupert
Nov 23, 2014
198
199
c class
caravaning on and off 10 years
i assume terry is leaning towards a carbon build up problem, probably around turbo. if its low mileage and been driven carefully / slowly, then may be" terraclean" would help. thats if you can get it back on the road...reading the codes will only point you in the right direction i.e. low boost etc. its not magic, the operator has to use his experience/knowledge (or get lucky changing parts at your expense). anyway I'm following the thread with great interest, and hope it doesn't break your heart, or wallet. best o' luck with it David
