Anyone have an issue with there Maxfan , when switching on the dan works ok but the hood doesn't open unless I do it manually , anyone else have the same issue.
After a few months laid up, mine sort of hesitates before opening sometimes. Seems like the seal on the raising canopy is sticking to the roof. I'll get up on a ladder and try spraying silicone oil on the rubber seal.
If mine hasn’t been used for a while I will raise it via it’s knob, then use the motor after that. It gets stuck to the rubber stops whilst down too long, so the safety system stops it keep trying.
