Marker lights wont turn off
Denbo 115
Wigan
Elddis autquest 115
On elddis autquest 115 marker lights wont turn off unless harness in door pillars unplugged
Denbo 115 Do you know if you van has an interface module, if so start your investigation there. Or follow the pillar loom back to it's source. There will be a connection somewhere/somehow between Vehicle electrics and Hab electrics for road lights.
I have had similar issues in the past. One common cure is to disconnect the battery for 10 minutes and then reconnect. It re-boots the ECU and body control module.
Geoff
Thanks I will give it a go it's a 213 model
If the re-boot does not work , as Diabalo has suggested , there may be a separate small module with 4 x fuses that could be near the main habitation PSU / fuse box or within or near the driver side door pillar and this unit (made by CBE) may have a faulty marker lights relay within it.
