LPG main isolator valve
Lymm, UK
Rollerteam Toleno r
Since Oct 2014
Rollerteam pvc underslung tank where is the master isolator for the gas for ferry purposes. individual valves under sink . not sure cant find info in handbook. Anybody on pompey santander tonight?
Solution2
There should be a valve on the outlet from the underslung tank, it'll be just before the regulator.
Hope you have a great time...envious, only bit!
Allen
Normally their is a valve you screw shut on outlet of the LPG tank
When we had an underslunh tank we just turned of the internal isolaters for the tunnel
Cheers, just put my scruffs on and went underneath. Its a stako cylinder all enclosed valves . i think like you. all internal valves to off should suffice.
Allen
Solution
Allen
Only had van a short time so not too familiar with its systems. Will soon find out!!! Theres a cover over all the tank valves "stako" logo. ill close off all the valves under sink.
Ours is an isolator switch near the door.
If you have a remote contents gauge with a button, if its lit up its on. Other than that if you unscrew the alloy cover on the tank there is a shut off valve in there. But as stated if you turn the isolator vales of usually four and show whoever wants to check should be ok. This will save crawling under the van.
but the gas will be live between the tank and the manifold high pressure to the regulator and low from regulator to manifold
