- Oct 19, 2020
- 20
- 13
- don't own one yet
- i'm a newbie
Cars use a liquid take off not vapour. Butane won't vaporise at low temps.We use autogas and have never had a problem. How do you think LPG cars, which run on Autogas, work in the winter?
Car systems have the liquid heated by the engine cooling water in the vapouriser where it is turned to gas for the gas fuel injection so it doesn't really make a huge difference once the petrol has started and warmed up the engine prior to LPG kicking in.Cars use a liquid take off not vapour. Butane won't vaporise at low temps.
I was reading this article, I didn't realise it was all propane in the UK :https://www.caravanguard.co.uk/news/all-about-gas-for-caravans-or-motorhomes-11701/We use autogas and have never had a problem. How do you think LPG cars, which run on Autogas, work in the winter?
They have heated regulators and vapourisers even with pure Propane the regulator would soon freeze .We use autogas and have never had a problem. How do you think LPG cars, which run on Autogas, work in the winter?
There are gas only cars available, we have a 2019 gas only Ford Transit in our workshop nowYes, on Retro fits.
Thats why you keep the Petrol tank and they always start off on Petrol.
I think that was clear, just another example of thread driftSorry I should have been clearer, I was asking the queation in relation to cooking and heating
Lots on sale in Belgium and LuxembourgThere are gas only cars available, we have a 2019 gas only Ford Transit in our workshop now
A 100% LPG car could use a number of techniques. You could use electric pre-heat (possibly including a vapour pre-heat once electrified). However, my money (without googling) is actually on liquid injection (i.e. just like they already burn liquid petrol).Lots on sale in Belgium and Luxembourg
100% LPG
Dacia Bi-fuel: Our LPG vehicles - Dacia UK
Find out everything you need to know about LPG and discover Dacia Bi-fuel. How LPG works, its advantages, and the range of Dacia Bi-fuel vehicles.www.dacia.co.uk
Ice forming isn't a problem itself with Propane, except that you may need to keep children and animals away to avoid burns. The propane itself will go down to -40C. However, you do need to ensure that you can take off the amount of gas you require at the temperature you have with the size of cylinder you have. Large full cylinders (with large wetted surface area) can vaporise more gas than small empty ones. Most underslung tanks are large enough to give 7kW all the way to empty, even at -2C. However, if you want 28kW to run a combi boiler at that temperature, things might be different and require a pretty large tank, or some sort of tank heating.I use a gasit tank in my works van for running a 7kw gas burner. I’ve worked in -2 to -3c sometimes running gas for 1 To 2 hours. Never had a problem plenty of ice forming on outside of tank, only thing is I keep regulator out of the weather.
Spot on. Butane is a mix of n-Butane and I-Butane - they differ very slightly in atomic structure. Mostly in UK is is mostly normal Butane so sits at about -2°C at ambient pressure. ISO Butane which was a large component of Butane we loaded out of Flotta in the Orkneys used to sit at about -10°C.Cars use a liquid take off not vapour. Butane won't vaporise at low temps.
