LPG fill point where? Not a inside or outside question. (1 Viewer)
Jan 27, 2018
2,674
2,125
Northampton
Rapido & Bongone
Not a inside or outside question. On my 604 the obvious place is in the skirt between the Hab door and gas locker. Is the skirt strong enough? Does it need a plate behind skirt? where have you fitted yours? Another place suggested was the towbar, rear face or side facing. This would be at least 3m to the locker, needing a connector. Any comments. Yes inside the locker would be easy.
Jun 16, 2017
323
583
Bridlington
Pilote P650GJ
Happy to help
Inside can cause issues with attendant on forecourt stations, if you check your skirt I’m pretty sure you will see strengthening struts I have put mine along side to avoid flexing when filling it works perfect for me
Jun 23, 2011
426
760
Pedreguer, Spain
Low profile
Since 2011
Dave Newell fitted my LPG filler here on my Rapido 646. No strengthening needed, ABS is strong enough here.
OG1
Dec 9, 2013
173
63
Sutton on Sea camping
RAPIDO 7066F
Since 2008
Our LPG is in the gas locker door. Plus one ordinary tank. Just in case we are unable to find a LPG station.
Sep 25, 2009
793
1,386
south yorkshire
since 2004. Tugger 10 years on and off
Mine's fitted in skirt just below gas locker. Rapido 785f.No need for strengthening
Campervan_man
997
1,720
Dethleffs Globebus
Remember to paint or use sealant to fit the gaslow point hole edge as the aluminium will oxidise and the paint will bubble over time if left unprotected.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Mine is in the skirt but center rear is a great option fill from either side
andynkim
107
200
Mobilvetta K-Yacht 85
I plan this in the new year, I will be fitting filler in the gas locker and see how I get on. Can always move it into the skirt at a later date if I have any problems and will be easier to move to another van in the future.
Dec 2, 2019
3,585
7,770
Amersham
van conversion
Since 2019
When I did mine, I made backing plates of 9mm ply glued at the back, sandwiching the body panel. For the gas, ehu and water fill up, it helps with flexing of the body panel.
Mar 23, 2012
9,545
32,094
sleights
c class
Like others ours is in the locker no problems so far after 5 years.
the1andonly
Jan 27, 2018
2,674
2,125
Northampton
Rapido & Bongone
Thanks for the resurection.
I have fitted mine in the locker, with the intention of keeping options open.
The only problems so far have been with a large Shell shield interferring with the locker whilst rotating. I've used a 90 degree bracket in the cupboard. The silver grey plastic is quite flimsy. To the right of the locker is the cab
Jul 29, 2013
9,071
18,523
Salisbury
Hymer B678DL A class
In the skirt ours is alloy and it is very rigid but only used the small black type you have a job to even see it in my picture
Sep 12, 2016
2,267
5,038
Chesterfield England Tellus 3
Lunar Roadstar 800
6 years
Our filler is on the top of our Gas Locker door great as I find bending difficult
Had it inspected when fitted the gas fitter had no problems
filled up all over Europe without any problems
