LPG connect problem Spain (1 Viewer)
Busman
1,766
4,332
Wirral
Esterel
A few years
The last 3 times I've tried to connect the nozzle I've struggled even with the help of the attendant, the last time after trying the attendant went away and came back with a very similar attachment with locked on straight away, can anyone tell me the difference and were I can get one. They where bought as a bag of 3 from gas it and the Portuguese one work OK.
Ta
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
Obvious difference here is the diameter of the hole, the smaller one is what she came back with but would that make a difference to locking on
May 31, 2015
11,740
44,747
Ducato PVC
Getting Better
I would try it at another filling station before I got another one as the pump you tried may have been worn or had a problem, saying that though if you can get another one fairly cheep then having one as backup would be good..
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
Thanks for the reply, it was 3 different garages.
Aug 5, 2012
118
125
Hitchin
Swift Escape 644.
since 1970's
Hi I bought mine from Gasit and struggled the first time in Spain with it and some times with fillips in France.
As my Bottle is in the gas locker and a little high i make sure that i am not stretching to hold the filler and press the button at the same time and after a couple of goes it seemed to get better.You also said it was in the bag with kit, but I found I had three adapters but not a Spanish one,I had someone bring me one out that I ordered on line.
53,675
150,921
There are two types of adaptor one with a non-return valve one without. Your filler point will have a built in non retiurn valve so you need a straight through adaptor but it shouldn't make any difference to locking on just safer to fill with one without the non-return valve as you don't get a build up of liquid gas between the 2 valves, also sometimes they won't fill with 2 valves.
If your adaptor has the valve you can drill of punch it out.
