Lower Body Panel Skirt Fixings
Burry Port South Wales
Since 2003
Having replaced our Rapido large rear garage door, I am looking for some fixings to reattach the lower grey skirt panel. It fixes with 3 screws through the lower door section but with push on studs at the top.
What I need is about 150mm of the grip bar and 3 of the studs.
The photos show the aluminium grip bar and then the stud mounting track with stud.
I may be able to get them from Rapido, however there is at least a 6 week delivery, so if anybody knows of a supplier where I could get them quicker it would help.
Edit, Last picture showing profile of aluminium Grip bar extrusion.
Chee
Sheddy Could you not get someone with 3d printer to make you some PaulandChrissy do things like that? I’m not sure about the strength of it though? Worth asking🤔😊
How about D82 bumper fastners. Not exactly the same but might do the job.
Eddie something like carpet/ tile trim might do?
Yes that may work, I'll check the dimensions of the serrated section and see if I can get a matching stud to fit that, and the panel.
The new door without the panel, and the old door with the panel fitted.
I need three pieces of the extrusion to fit in the precut slots (blue) on the new door to accept 3 studs fitted to the inside of the panel. They will not take any weight as the panel is fixed with three screws through the pre-drilled holes at the base of the door.
Note: The low hanging cables will be relocated on completion. :rofl:
