F4K EM
- Jan 31, 2020
- 7
- 17
- Coach built
We had to return home last week from Spain when heading to Algarve in our Rollerteam Granduca. Having driven through France and into Spain up and down the hills as normal.
I noticed the mpg was way down from the expected 30ish to 26. Then on just a steady incline using cruise control, the speed dropped gradually without dropping out of cc. It drove ok on the flat but struggled on inclines then on any hill I was dropping to 3rd to make it and the EML came on.
Got to nearby Salamanca to Fiat dealers. No one spoke English but diagnosis showed possible EGR and it was seen the fuel filter case was cracked and leaking diesel. That was replaced for €350. Set off again next day but light came back on on the first hill. Back to Fiat. They then cleaned out the EGR and air intake system for another €150 and test drove it. I went on second test drive with mechanic driving and knew it wasn't cured, then light came back on! Due to the language barrier and
Knowing it was mainly downhill back to Santander, I cut my losses and got ferry home.
Come the day of getting into my usual garage, the the EML wouldn't come on despite taking it to Matlock for some decent hills which I had to crawl up in 2nd gear.
They plugged it in anyway and it showed intermittent EGR fault. SO they put a new EGR system on for £300. Went a ride next day but still no good and light came on on a gradual incline. Got it back to garage without switching off. Diagnosis still showed EGR so they said it must be the solenoid switch for EGR.
THe solenoid was replaced for £125 and you guessed it, its still the same but with no light coming on.
It's now booked in for Wednesday when the main mechanic is back off holiday!
I would be glad to hear of similar experiences and what the outcome was or expert knowledge from any mechanics.
The van is a 2010 Ducato 2.3 multi jet 120hp with 61000 miles. It drives fine on the flat with or without cruise control then dies on long inclines and completely struggles on proper hills.
