I am in the process of changing to Lithium for LB. I have had to change the position of charge controllers due to length of temperature sensors hence some things are up for grabs. (Battery has bluetooth BMS)
I expect to be laid up for long periods, and used in others. Lets call them summer and winter.
Summer all things are on
Solar A and Solar B and B2B. Votronics 1212-30, Solar A 330W panel Votronics mppt350 output to LB Solar B 120W+100 panel Votronics mppt250 duo output to LB 2nd connected to SB
Winter (L battery 50-70% SOC) Storage no charge. still need to charge SB
Solar A panel issolated. Solar B panel connected output to LB issolated 2nd connected to SB.
The winter scenario any comments? will the controller still work with no 12v on the output? Will i be better off each time rewiring Solar B or some other option. Would i need to issolate LB terminal to prevent B2B interfering
