So atm in our MH ( a 2017 Autosleeper Kingham) we have 350w solar fitted which is connected to a victron solar charge controller.
3 x 110 AH Varta lead acid batteries.
A 60amp sterling B2B charger ( now broken.)
A 1500w pure sine inverter used to power a microwave, hairdryer and laptop.
The Factory fitted AC - DC charger ( which I don't think is any use for lithium)
So our current lead acid set up is just not cutting it, that along with the fact that our sterling 60A B2B charger has packed in has made me decide its time to take the step to lithium, I am looking at this 60A B2B charger to replace the broken Stirling one, is Renogy and good?
<Broken link removed>
And either two of these TN100AH Lithium batteries
www.tayna.co.uk
OR a single 200AH battery
www.alpha-batteries.co.uk
Now I have a few questions
1. Are any of the batteries good? Are their different qualities of lithium batteries the same as there is with lead acid?
2. should I buying a larger single battery or buy two smaller batteries?
3.Apart from the lithium batteries is there any sort of controller that I need to purchase, or just buy batteries, set lithium profiles on solar controller and B2B charger.??
4. As for the AC-DC charger does anyone know if the factory installed charger is suitable or not suitable for Lithium??? If not then I have a separate 7 stage charger that I will install to charge the batteries when at home.
in our setup we also have the victron Bluetooth battery monitor with the shunt to measure everything, will this be able to measure individual cell voltages in the lithium batteries , ( is this something that I should make sure that I am able to monitor with Lithium batteries ?)
TN Power 100Ah Lithium Leisure Battery LiFePO4 (TN100)
The TN Power TN-LFP12.8V100AH lithium battery utilises lithium iron phosphate technology which produces a significantly better depth of discharge and number of cycles than conventional lead acid batteries. It is also up to 50% lighter than lead acid batteries, completely maintenance free and has...
12V 200AH POWEROAD BASE LITHIUM LIFEPO4 BATTERY (N/A) - Alpha Batteries
Poweroad- Time to go Lithium
