Lights under bed Burstner 640.
Gumby
Burstner 640
20 years
Hi, the drop down bed has two lights in the lower part to be used when its in the raised position . I cant get them to work does anyone know if they have a seperate fuse to all the other lights please as they dont appear to have power to them . Thanks
I assume you know that you push the light fitting to turn them on and off?
forget that, that operates the above bed lights.
Must read posts properly first!
have a look at the wiring under the drop down bed mattress. There might be a loose connection.
is this the one with a microswitch on the bed mechanism that turns them off when the bed is lowered?
